查看: 4298|回复: 1
[Firmware update] Open source for ES15? 470rpm reverse at 220/360rpm
发表于 2022-2-5 14:42:42 | 显示全部楼层 |阅读模式
Hi is there going to be open source available for the ES15? Also is there anywhere i can view a changelog? With firmware V1.02 Level 1 Torque control feels perfect set to 360rpm with excellent torquing sensitivity, it tends to overtighten sometimes at 470rpm if i'm not being careful. It would be nice to to have the option to keep the reverse at 470rpm even when forward is set to 220/360rpm
发表于 2022-2-8 14:49:11 | 显示全部楼层
Please try the ES15 V1.03 firmware, We fix some bug
https://www.minidso.com/forum.php?mod=viewthread&tid=4589
GMT+8, 2026-11-6 00:55 , Processed in 0.158894 second(s), 21 queries .
