查看: 5520|回复: 3
[Troubleshooting] Different display options
发表于 2021-10-13 15:17:39 | 显示全部楼层 |阅读模式
I love this little power supply, a great addition will be to be able to change the display so I can see bigger information for output volts, amps and watts, is there a way to do that?
If not posible this will be great to have as an option, I need to monitor output volts, amps and watts as I do my work and the small digits in the bottom part of the display just don't work very well.
Thanks!
发表于 2021-10-14 09:09:12 | 显示全部楼层
Thank you for your suggestion, we will further improve the firmware of MDP in the future
发表于 2025-7-3 20:04:25 | 显示全部楼层
Good day.
I really like your products. I wanted to buy the MDP series devices for a long time. But here I was disappointed. The design is amazing, as always, but it is very difficult to use because of the small font, which is difficult to see. Please increase the font size in this part of the screen and add discharge time and capacity to main screen.
Thank you.
发表于 2025-7-4 08:58:20 | 显示全部楼层
Thanks for the suggestion. The font size is related to the display size. Too much information needs to be displayed on the same screen. But increasing the discharge, load time and total watt-hours can be considered.
GMT+8, 2026-11-6 00:50 , Processed in 0.183310 second(s), 24 queries .
