查看: 4197|回复: 1
TS80P Reboots whilst cooling down to sleep mode
发表于 2021-10-12 22:14:07 | 显示全部楼层 |阅读模式
I have had my TS80P for a couple of months, I bought it to help demonstrate soldering to my students. However, I have found that there is a problem.
After 180 seconds of inactivity it goes into sleep mode as it should and I see the temperature on the screen decreasing, but if I pick it up again while it is cooling down, instead of coming back to life and heating back up again, it reboots .
However, if it cools all the way down to the sleep temperature then when I pick it up it heats up again like it should. This happens when it's plugged in to the mains power supply it came with, but not the portable power bank I use. The mains power supply is the one that came with the TS80P, could it be the problem?
Thank you!
发表于 2021-10-13 09:19:00 | 显示全部楼层
Very strange problem, can you send the video of the problem to service@minidso.com?
GMT+8, 2026-11-6 00:55 , Processed in 0.166277 second(s), 21 queries .
