查看: 9558|回复: 5
Error on firmware update 1.08
发表于 2021-7-13 22:28:19 | 显示全部楼层 |阅读模式
Hello, I got my new DT71 with firmware 1.06. When trying a firmware update to 1.08 the file will be renamed to .err. After restart firmware is still on 1.06. Please give me some further advice. Thank you Jörg
发表于 2021-7-15 09:20:45 | 显示全部楼层
What OS do you use? Can you try other computer?
发表于 2023-4-5 15:54:47 | 显示全部楼层
I have the same problem. Current Version is 1.06. I tried to update to
  1) V1.08  -> got DT71AP~1.ERR file
  2) V1.13  -> got DT71AP~1.ERR file
  3) V1.15  -> got DT71AP~1.ERR file
no .rdy file at all.
My System is a MacBook Pro, MacOs Ventura 13.3. I Use an USB-C to USB-A cable and an USB-A to USB-C Adapter. This work fine with the MDP-P905 so I think it is not a cable problem.
Thanks for you help
TS80P, TS100, LA104, DT71, MHP30
发表于 2023-4-6 09:08:23 | 显示全部楼层
Can you try Windows?
发表于 2023-4-7 16:02:36 | 显示全部楼层
Yes, I have.
It works fine with Windows 10. I've updated to V.1.15.
But I don't understand why there are problems with MacOs with only some devices.
Are there dependencies to the DFU Version? My Tweezer has DFU V3.52.
Is the DFU Software upgradeable?
发表于 2023-4-10 09:39:29 | 显示全部楼层
This is a software compatibility issue, but DFU cannot be upgraded by users.
GMT+8, 2026-11-6 00:54 , Processed in 0.159211 second(s), 21 queries .
