查看: 4763|回复: 1
[Troubleshooting] ES120 completely dead.
发表于 2021-3-27 03:25:37 | 显示全部楼层 |阅读模式
Hi, I have an about 1 year old TS120, it was working fine. after I was done using it yesterday, I left it connected to my pc to charge it as usual, and then I put it away.
Order time:                09:25 Jun. 26 2020
Today, when I wanted to use it, It was slow, and I saw it said Low Charge, Ok, I guess it didn't charge properly. So I connected it to the pc again. I held the button, and the firmware update folder came up.
I then disconnected it, and re-connected it without holding the button, and It lit up.  after 10 minutes, it was completely dead.
It does nothing now. I've tried 3 different cables, and several different chargers, but it does absolutely nothing now...
发表于 2021-3-29 09:39:22 | 显示全部楼层
Hello, customer
If any questions with the products, please send an email to service@morningtools.com with pictures or videos about your problem.
Thank you.
GMT+8, 2026-11-27 09:52 , Processed in 0.312957 second(s), 21 queries .
