查看: 4770|回复: 1
[疑难问题] Just shows USB Mode and switches off
发表于 2021-3-11 03:47:56 | 显示全部楼层 |阅读模式
Hi, have just received one.
Upgraded M01 without any problems (bin file, hex hasn't worked).
Tried to upgrade firmware to P905, it doesn't appear as a drive. When then tried to use power supply, it shows "USB Mode" and switches off. When I try to connect USB, it blinks with some firmware information and switches off.
And doesn't work =/ How to fix it? Used different Type-C cables, same problem ((
发表于 2021-3-11 09:15:54 | 显示全部楼层
Please send an email to service@morningtools.com with pictures or videos about your problem.
Thank you.
GMT+8, 2026-11-6 00:53 , Processed in 0.151517 second(s), 21 queries .
