查看: 6818|回复: 2
[Troubleshooting] Problem with Sen-Err
发表于 2021-1-23 23:21:07 | 显示全部楼层 |阅读模式
Hello .I bought a TC100 soldering iron for Ali Express, he does not want to work. .When connecting the power supply, it gives an error. When you press button A, it shows the temperature of 498 degrees and then shows the error Sen-Err. Please, help
发表于 2021-1-25 13:46:16 | 显示全部楼层
Hello, customer
If you have any questions with the products, please send an email to service@morningtools.com with videos about your problem.
Thank you.
 楼主| 发表于 2021-1-26 20:40:09 | 显示全部楼层
figured out my problem. The problem was not with the soldering iron, but with the extension cord. The soldering iron works great
GMT+8, 2026-11-6 00:53 , Processed in 0.156844 second(s), 20 queries .
