查看: 7297|回复: 0
DT71 won't turn on or charge
发表于 2020-11-25 00:23:44 | 显示全部楼层 |阅读模式
When I try to charge the device with the USB C connector it does give a red led indicator. It will never turn off, even letting it charge for a couple of hours.
When connecting the display unit while charging it gives this screen:
DFU:V3.52
5.230V
but when I disconnect and connect the display to the tweezers it does absolutely nothing.
I tried to upgrade to the latest firmware DT71APP106.hex but when I try, the hex file is replaced with the file attached.
GMT+8, 2026-11-6 01:01 , Processed in 0.153815 second(s), 20 queries .
