查看: 6026|回复: 1
Parameter source on/off
发表于 2020-6-3 23:16:53 | 显示全部楼层 |阅读模式
Hello, after updatingto firmware 1.7 the "source on / off" item appeared in the menu of the ts80. What is its function?Thanks
发表于 2020-6-4 09:20:06 | 显示全部楼层
Some power bank do not support low current output,
This switch enables the ts80 to support this power bank.
GMT+8, 2026-11-6 01:04 , Processed in 0.145953 second(s), 21 queries .
