查看: 5656|回复: 1
[Troubleshooting] ES120 Only rotates 1/4 way around
发表于 2020-4-26 03:53:41 | 显示全部楼层 |阅读模式
I recently purchased a ES120 and only used it 1 time successfully.  After that when I press the button and twist, it will only rotate 1/4 turn then stop.  Is this an issue I can fix myself, or do I need to try and return the device?
发表于 2020-6-10 11:22:02 | 显示全部楼层
Hello, customer.
If any questions with the products, please send an email to service@morningtools.com with pictures or videos about your problem.
Thank you.
GMT+8, 2026-11-6 01:04 , Processed in 0.152382 second(s), 20 queries .
