查看: 7211|回复: 2
TS80 homemade power banck
发表于 2018-11-20 07:07:27 | 显示全部楼层 |阅读模式
[i = s] posts by netmonk in 2018-11-20 07:11 Edit
I bought an QC 3.0 Anker PowerCore Speed 20000mAh working very fine with the TS80. But i was also reconditionning 18650 from laptop battery.
having plenty of cells in my carton box i decided to build a custom battery pack.
I ordered a chip on banggod supposed to be qc3.0 compatible, but in fact i was unable to really power my TS80.
This is when i remember i also have an ISDT battery charge tester which can also charge via usb, powered by lipo.
I tested it with the TS80 and it worked like a charm.
About my full build :
https://secondlifestorage.com/t-After-destroying-time-to-make-my-first-build
Or also on instagram : https://www.instagram.com/p/BqYREenAiF9/?utm_source=ig_web_copy_link
GMT+8, 2026-11-7 18:38 , Processed in 0.524538 second(s), 26 queries .
