查看: 6908|回复: 1
[Troubleshooting] Loose LCD/microusb in ES121
发表于 2018-11-3 20:22:46 | 显示全部楼层 |阅读模式
Is normal that the lcd moves inside when plugging and removing the usb charger? it seems the internal part has 1 mm of play horizontally
发表于 2018-11-5 09:59:40 | 显示全部楼层
Maybe the circuit board is shaking, will it affect the use?
GMT+8, 2026-11-27 09:52 , Processed in 0.311468 second(s), 21 queries .
