查看: 12616|回复: 5
How to format the internal storage
发表于 2018-1-30 06:21:38 | 显示全部楼层 |阅读模式
I'm looking for a way to format the internal 8MB storage. It has worked great, but today the drive wouldn't show up when connected to the computer. As there is no obvious option on the DS212 to format the storage, I used disk management on my computer (Ubuntu 17.10) to format the storage device as FAT. After doing this it mounts and I can see the files, but every file written contains garbage and nothing saved on the DS212 can be opened (as intended) on the computer.
So, how do I go about properly reformatting the built-in storage?
发表于 2018-1-30 08:56:26 | 显示全部楼层
just format it with "FAT"
 楼主| 发表于 2018-1-30 09:47:04 | 显示全部楼层
I tried that, both using
  1. mkfs.vfat -nDSO /dev/sdb
复制代码
and
  1. mkfs.vfat -a -nDSO -F12 /dev/sdb
复制代码
. The files still come out corrupted, but the preferences seem to be persistent still.
  2. identify-im6.q16: improper image header `IMG_000.BMP' @ error/bmp.c/ReadBMPImage/606.
  4. 00000000  36 35 20 4c 31 39 30 31  2c 20 20 36 33 20 4c 31  |65 L1901,  63 L1|
  5. 00000010  39 30 32 2c 20 20 36 30  20 4c 31 39 30 33 2c 20  |902,  60 L1903, |
  6. 00000020  20 35 37 20 4c 31 39 30  34 2c 20 20 35 35 20 4c  | 57 L1904,  55 L|
  7. 00000030  31 39 30 35 2c 20 20 35  33 20 4c 31 39 30 36 2c  |1905,  53 L1906,|
  8. 00000040  20 20 35 32 20 4c 31 39  30 37 2c 20 20 35 30 20  |  52 L1907,  50 |
  9. 00000050  4c 31 39 30 38 2c 20 20  34 39 20 4c 31 39 30 39  |L1908,  49 L1909|
  10. 00000060  2c 20 20 34 39 20 4c 31  39 31 30 2c 20 20 34 39  |,  49 L1910,  49|
  11. 00000070  20 4c 31 39 31 31 2c 20  20 34 39 20 4c 31 39 31  | L1911,  49 L191|
  12. 00000080  32 2c 20 20 35 30 20 4c  31 39 31 33 2c 20 20 35  |2,  50 L1913,  5|
  13. 00000090  31 20 4c 31 39 31 34 2c  20 20 35 32 20 4c 31 39  |1 L1914,  52 L19|
  14. 000000a0  31 35 2c 20 20 35 34 20  4c 31 39 31 36 2c 20 20  |15,  54 L1916,  |
  15. 000000b0  35 36 20 4c 31 39 31 37  2c 20 20 35 38 20 4c 31  |56 L1917,  58 L1|
复制代码
发表于 2018-1-31 10:22:20 | 显示全部楼层
noccy 发表于 2018-1-30 09:47
I tried that, both using  and . The files still come out corrupted, but the preferences seem to be p ...
Please use Windows 7 and above format disk.
发表于 2024-9-21 20:27:27 | 显示全部楼层
I had the same problem. I was able to format it using linux:
sudo mkfs.fat -F 12 -n DSO211 -s 1 /dev/sdb
GMT+8, 2026-11-6 00:50 , Processed in 0.155414 second(s), 20 queries .
