查看: 11176|回复: 8
[疑难问题] Possible to Change Gear
发表于 2018-1-28 22:22:14 | 显示全部楼层 |阅读模式
Hi, I'm new to the community.
I've just received my ES121 after seeing good reviews on youtube.
Have to say what a fantastic product, the design and finish is second to none.
I do have a problem, however, the torque produced on 121 is not enough for the work I do( model helicopters mainly) any residual thread locker present on my screw, the 121 will not able to handle.
I know I should have gone to 120 which has a higher torque, but who don't want the newest and shiniest toys right.
Also, as I saw on the youtube videos, 121 has radial and thrust bearing which is what I like. they make 121 more durable. And since I already used mine, I cant just tell the seller I want another type.
So I'm asking is it possible to change the gears in my 121 into something stronger like the ones you used in 120?
 楼主| 发表于 2018-1-28 22:45:23 | 显示全部楼层
Or is the gearbox interchangeable between these two versions? and is that open for sale?
 楼主| 发表于 2018-1-28 22:47:55 | 显示全部楼层
有中文论坛的
不是装X哇,没看见,自己人自己人
求购齿轮组哇?已经买了121,感觉扭力不够用的,用过了不好退换,又不舍得出二手。
求购齿轮箱
发表于 2018-1-29 10:17:13 | 显示全部楼层
感谢您喜欢我们的产品。新的ES120和ES121都是推力轴承。
确实有收到类似需求,ES120和ES121都有。正考虑出一个解决方案。
发表于 2018-1-29 10:19:42 | 显示全部楼层
袖珍示波器交流QQ群:131363234    Mini烙铁交流QQ群:101978268
加群吧
 楼主| 发表于 2018-1-29 10:22:02 | 显示全部楼层
太牛了!都有轴承,如果不拆的话,怎么看出来是新版的es120还是旧版的?
因为一听你说都有轴承,我有跑去买了个120
发表于 2018-1-29 15:22:04 | 显示全部楼层
新改版的ES120前端和ES121结构是一样的
发表于 2018-1-29 17:57:32 | 显示全部楼层
还有,兄弟你为什么会用英文发帖啊,以为好东西都是国外做的?
泪奔
 楼主| 发表于 2018-1-30 01:49:59 | 显示全部楼层
不是啊,是因为去固件下载那里,一群人都是讲英文的,我本来以为我们产品主要外销的
GMT+8, 2026-11-12 08:30 , Processed in 0.151616 second(s), 21 queries .
