查看: 10564|回复: 5
[Troubleshooting] ES120 Battery is Dead After 2 Days
发表于 2017-12-30 15:44:05 | 显示全部楼层 |阅读模式
I fully charge my ES120 and put it into the case.  After 2 days, the battery is dead when I try to use it.  I need to charge again or plug it in to use it.  After charging, I check after 1 day and see that the screwdriver battery is nearly 1/2 drained.  Nothing is pushing the button when it is in the case.  Is there a bad circuit causing the battery drain or a bad battery?
发表于 2017-12-30 23:38:10 | 显示全部楼层
have a pictuer or video of probrom?
 楼主| 发表于 2018-1-5 13:14:08 | 显示全部楼层
Hello.  I am attaching pictures of the problem I described.  I fully charged the ES120 battery and confirmed again after placing it into the case.  After 2 days, I checked to see that the battery is dead.  The same thing happens when I just charge the ES120 and place it on my table for 2 days.  I have not used my ES120 for more than 15 minutes total.
 楼主| 发表于 2018-1-5 13:25:51 | 显示全部楼层
litesp Posted 2018-1-5 13:14
Hello.  I am attaching pictures of the problem I described.  I fully charged the ES120 battery and c ...
 楼主| 发表于 2018-1-5 13:29:26 | 显示全部楼层
Sorry for the multiple posts.  I can't seem to confirm that the pictures uploaded correctly.
发表于 2018-1-5 16:39:39 | 显示全部楼层
Don't warry, mail the picture to service@minidso.com , We will help you.
GMT+8, 2026-11-27 09:52 , Processed in 0.150104 second(s), 21 queries .
