查看: 7892|回复: 1
DSO 203 HW on boot screen different than PCB marking
发表于 2017-12-14 05:27:44 | 显示全部楼层 |阅读模式
I was wondering what is the correct way to check the hardware version. While browsing on different sites for a DSO203, I found some conflicting HW versions. For example:
1. boot screen: HW 2.82 but inside PCB has V2.6
2. boot screen: HW 2.6 but inside PCB has V2.72B
Which number to trust? The one on boot screen or the one marked on the printed circuit board?
Thank you,
Iulian Cioarca
发表于 2017-12-14 09:23:33 | 显示全部楼层
The hardware version is based on the PCB.The boot screen and PCB display are not consistent because they artificially reload other versions of the underlying firmware.In normal circumstances, boot screen and PCB's version Numbers are consistent.
Thank you
GMT+8, 2026-11-11 14:36 , Processed in 0.151160 second(s), 21 queries .
