查看: 11219|回复: 1
SC212 protective rubber case
发表于 2017-9-27 17:43:08 | 显示全部楼层 |阅读模式
Description
SC212 is a customized special protective silicone case for the oscilloscope DS212.Ithelps absorb potentially damaging physical shocks to your  oscilloscope, while giving you unobstructedaccess to all connectors and controls. Being made of rubber, the protectiverubber case also helps prevent your S DS212 oscilloscope from damaging glass orpolished surfaces. SC212 is made of highly flexible and highly elastic importedsilica gel. SC212 is sprayedwith light oil. A ring stand is for free with the SC212. The stand can be convenient for useroperation and carry.
Features:
  • Light weight durable silicone rubber case
  • Easily attaches around your DS212
  • Helps protect your DS212 from scuffs, scratches anddamage
  • Custom designed for DS212, all input ports and holesaccessible
  • Weight: 25 grams(with stand)
  • Dimension:105x65x17mm
  • Available in red, yellow & black
Part List:
  • 1 x CS212 Protection Boot
  • 1 x Ring Stand (free gift)
Link to order:   https://item.taobao.com/item.htm?id=558903706435
销售店铺  ccdso.taobao.com
(Miniware代理商)
GMT+8, 2026-11-15 17:50 , Processed in 0.166946 second(s), 25 queries .
