查看: 9537|回复: 9
DS203 Bad thumbwheel switch
发表于 2017-8-11 04:40:45 | 显示全部楼层 |阅读模式
Hi,
My DS203 thumbwheel switch  on the corner is bad. Only to right side works and feels good but to the left its hard to press.  I want to replace it.  Please help me find this part.
Thank you.
发表于 2017-8-14 16:11:01 | 显示全部楼层
We have a new product, the DS212 oscilloscope. Are you interested in challenging the creation of DS212 third party firmware? If you want, I can post a DS212 to you.
回复 0 1
 楼主| 发表于 2017-8-11 06:37:10 | 显示全部楼层
After some google search I think I found it https://www.aliexpress.com/item/ ... fe/32790239186.html
发表于 2017-8-11 09:33:09 | 显示全部楼层
If you need, give me your address, I post to you. My firend.
 楼主| 发表于 2017-8-12 04:14:49 | 显示全部楼层
Great news!  I was able to fix it   The problem was with a defect in switch lever.  It was bent out so stopped the movement to the left when board inside shell.  I cut the small plastic piece off and now smooth operation.
Thank you for offering to send the part but not needed now.
Here you can see the problem.
发表于 2017-8-14 09:04:19 | 显示全部楼层
You have a great practical ability
 楼主| 发表于 2017-8-14 11:17:30 | 显示全部楼层
  I collected 3 weapons now. DS201, DS202 and DS203.
发表于 2017-8-14 13:56:35 | 显示全部楼层
More weapons is on the way
 楼主| 发表于 2017-8-15 23:09:22 来自手机 | 显示全部楼层
minidso 发表于 2017-8-14 16:11
We have a new product, the DS212 oscilloscope. Are you interested in challenging the creation of DS2 ...
Hi, it's not clear to me. Are you asking if I am  interested in writing coding a 3rd party firmware for DS212?
发表于 2017-8-16 09:17:35 | 显示全部楼层
flagmax 发表于 2017-8-15 23:09
Hi, it's not clear to me. Are you asking if I am  interested in writing coding a 3rd party firmwar ...
Yes.For example, the official APP is a horizontal display, try to write a APP is shown as a vertical display
GMT+8, 2026-11-19 21:00 , Processed in 0.154123 second(s), 22 queries .
