查看: 5839|回复: 1
New TS100 reboots and gives erratic temperature readings
发表于 2017-4-8 11:22:34 | 显示全部楼层 |阅读模式
I just received a TS100.  It powers on but when I press the first button to heat up, it reboots back to the startup screen and the tip never gets hot.
If I press the second button to take a temperature reading the numbers jump around from 30c to 300c and everything in between.
Here is a video showing the problem
https://www.dropbox.com/s/bpd3mpf8p18p1rf/TS100.mp4
Is it broken or is there anything I can do to get it working?
Thanks!
发表于 2017-4-10 09:27:14 | 显示全部楼层
What power adapter do you use?
Must be above 12V 1.5A
Recommended using 19V 2A
GMT+8, 2026-10-23 10:47 , Processed in 0.147481 second(s), 21 queries .
