查看: 7406|回复: 3
DS203 screen refresh
发表于 2016-11-28 01:08:35 | 显示全部楼层 |阅读模式
I have Oscilloscope-DS203 HW ver.2.6
Today after shutdown due to empty battery (I think so), the screed started to refresh every-4-5 seconds
Do you have idea what happened and how to fix?
I upgraded to last FW - FPGA261,Sys_152, App_253 , but I have same behavior
is it possible reset of the settings?
Thanks
 楼主| 发表于 2016-11-28 02:08:57 | 显示全部楼层
I mean the graph is refreshed every-4-5 seconds
the menu is OK
 楼主| 发表于 2016-11-28 04:01:03 | 显示全部楼层
I found the reason- delayed refresh is with long timing period
with microseconds it is realtime, but in milisecond range is with delay
this should not be dependant
is it possible to be fixed?
Thanks
发表于 2016-11-28 11:39:50 | 显示全部楼层
with microseconds it is realtime, but ...
What is your DFU version?
Firmware upgrade SYS1.64 to try, APP1.13
http://minidso.com/forum.php?mod ... &extra=page%3D1
Scan time base if you choose, scanning a cycle is long,
If faster, you can choose storage depth, in the right column "T0" to select the "360" or "0.5 k"
GMT+8, 2026-10-20 23:47 , Processed in 0.194457 second(s), 21 queries .
