查看: 10842|回复: 3
unable to power on DS202 while LED Blinks orange
发表于 2016-10-23 21:54:43 | 显示全部楼层 |阅读模式
Hello ,
I brought DS202 and used it to measure PWM signals. It worked fine sometime.
I switched it off by pressing power off .
I later found that it was still blinking orange led on top left corner.Even though i pressed POWER button for more than 2 seconds,screen didnt turn on.
I  initially thought it is Low battery ,hence tried connecting USB charger provided with device.
However,after couple of hours,i found that it was still blinking orange. I tried pressing power button but simply no response.
Any suggestions and help to trouble shooot this problem is welcome.
Regards
Shivchitt
发表于 2016-10-24 16:35:03 | 显示全部楼层
Click the power button is off screen, orange flashing is said to close the screen, the machine in standby state
Long press the power button 2S, will display shutdown operation interface, according to the prompt to turn it off
Long press power key to 8S, was forced to turn it off
发表于 2020-10-3 10:28:37 | 显示全部楼层
http://ibcibc.com/forum.php?mod=viewthread&tid=1136&page=77#lastpost
发表于 2020-10-4 11:11:06 | 显示全部楼层
GMT+8, 2026-11-6 00:59 , Processed in 0.145133 second(s), 21 queries .
