查看: 7072|回复: 4
HELP
发表于 2016-4-14 09:04:40 | 显示全部楼层 |阅读模式
Hello, I need help, I just got an DS203 on eBay and when I turn it on it say's: FPGA Configuration Err!
Hardware Version 2.81d serial number 8028C79B and Mini DSO SYS Ver 1.63
Í have try'd everything, upgrading the SYS, the FPGA, try'd everything and still doesn't boot
When I boot in DFU it say's:
Serial 8028C79B
Licence: 0DAE8079
DFU V3.45C
Please help, what can I do
djlsb@icloud.com
发表于 2016-4-15 09:53:28 | 显示全部楼层
 楼主| 发表于 2016-4-15 12:30:04 | 显示全部楼层
Yes thank you I already try'd all of that and still no luck.
My device has now the DFU V3.45C, before had the3.40 can be due to that?
I do everything I put each file one at a time and then i turn the device off and on again and it shows the same thing on the screenFPGA Configuration Error
发表于 2016-4-15 14:12:34 | 显示全部楼层
My device has now the DFU V3.45C, befor ...
What is your PC system, It is best to Windows 7.upgrade to first put. ADR, become. SET ,then put . BIN, and then becomg .RDY
 楼主| 发表于 2016-4-15 14:52:43 | 显示全部楼层
Yep I did that way on my windows 7 pc and on an windows 10 pc and nothing, thanks for the help
GMT+8, 2026-10-21 00:57 , Processed in 0.151994 second(s), 21 queries .
