楼主: minidso
[Firmware update] Material Download for TS100 Smart Soldering Iron
发表于 2017-5-11 16:19:11 | 显示全部楼层
[i = s] posts by FreeMaxl in 2017-5-11 16:32 Edit
minidso Posted 2017-5-11 09:39
We will soon release app V2.17, and source code of app V2.17
OK, first of all, You have done well good work on the Firmware ! Thank you.
So I just relax and wait for your V2.17 source-code release.
I just have some Ideas:
In Version 2.16 the Parameters for Sleep- and Idle-Time are (low)limited to 60 or 100 seconds.
I think its a good Idea to set the low-limits to 15 and 25 seconds. (if someone feels comfortable with short standby times)
(for myselfe I really often use the two-Buttons to switch-off the soldering Iron)
The Parameter "OffVolt" have an upper Limit from 12V:
I use the TS100 on my Motobike-travvels.  So I want to protect Battery from discharge.  Therefore the Parameter for "OffVolt" should be settable to higher Values.  I think 16 V is a good upper Limit for this Parameter.
If the Source-Voltage gets lower then the "OffVolt" Setting the Display just resets.
I think its better when first a Message is printed on the Display "! Low-Volt !" and then a wait-time of 3 seconds bevore the program go further. (so that the message is readable)  I think when the Voltage gets too low, a "global" wait-time is really ok. (because its a problem)
Maybe you want to change some of this in a possible 2.18 release. (or in 2.17 if it is not too much work)
回复 1 0
发表于 2017-5-11 21:32:23 | 显示全部楼层
I bought a TS100.  Very impressive.
Is there an english toolchain setup documentation?
I'm unable to determine  if this can be build with open source tools.
 楼主| 发表于 2017-5-12 09:48:43 | 显示全部楼层
I'm unabl ...
Development environment is IAR 6.4
发表于 2017-5-14 23:53:09 | 显示全部楼层
[i = s] posts by nicohirsch in 2017-5-15 00:00 Edit
FreeMaxl Posted 2017-5-11 16:19
I also need a higher "OffVolt" value, because I want to use the TS100 with my Bosch 18V batteries. So at least 16/17V as max value would be great.
Likewise the lower sleep & idle timer values are a good idea. The TS100 heats up very fast This would give the users more freedom - so why don't accept values from 5sec and let the user decide, what he wants. Even if it makes no sense for some people - it doesn't hurt anyone ;)
Another idea: It would be really nice to have an option to only show the picture (or something like "STANDBY") in standby mode. The alternating between the picture and Press is a little bit annoying - especially with that Press-Animation ;)
And what about an option to flip the screen for left-hander? (I think this is not that easy to implement)
Great work, by the way! I really like my TS100!
 楼主| 发表于 2017-5-15 09:16:59 | 显示全部楼层
We may update the contents in the next release
发表于 2017-5-16 17:07:58 | 显示全部楼层
Looking forwared to the new firmware
发表于 2017-5-17 15:29:52 | 显示全部楼层
nicohirsch Posted 2017-5-14 23:53
Yes, 5 sec is also good.  (I tried with older firmware and as result the Iron goes to sleep while soldering because accelerometer-sensor setting was not sensitive enough)
The option for left-hand was also in v2.16 release possible.
Now the new release v2.17 is online I take a look at it. :-)
发表于 2017-5-18 04:40:16 | 显示全部楼层
Hello again
I have found a little "problem".  Maybe the author of the new .zip file can add the "Library" - Folder to the source-code .zip file ?
Because when I trie to compile, then there are error messages because of the missing Libraries.
In old Firmware V2.12 there I found the Folder "Library" so I copied this and Put it in place so that the project can find it directly without changing options.
So I changed the Min/Max Values for my selfe and updated the firmware with my own version.
发表于 2017-7-7 20:30:17 | 显示全部楼层
I love the soldering iron.
FYI - Just following up with more info regarding my previous question.
I was able to use the info found below to compile the firmware using STM32
http://www.badcaps.net/forum/showthread.php?p=710815
发表于 2017-7-23 05:54:26 | 显示全部楼层
[i = s] posts by amv2000 in 2017-7-23 23:15 Edit
Instructions in Russian
TS100 Source File Description Interface Management_RU.pdf
4.08 MB, 下载次数: 254
перевод Андреященко
TS100 Source File DescriptionControl Managerment_RU.pdf
385.18 KB, 下载次数: 260
перевод Андреященко
TS100 Soldering Iron Instruction Manual_RU.pdf
2.23 MB, 下载次数: 289
перевод Андреященко
GMT+8, 2026-11-7 18:28 , Processed in 0.168841 second(s), 20 queries .
