楼主: minidso
DS202 Firmware update
发表于 2016-2-11 06:39:51 | 显示全部楼层
Do you place the DS202.V132A and DS202.V132B into the DFU root directory at the same time??
Or do one at a time a.hex first, re-booting the system then copy the B.hex in the DFU ???
What are the steps?
What do you mean by (after the upgrade, need to format a disk) from text above ? What disk do you format? Or do you mean the internal disk will automatically be formatted ??
 楼主| 发表于 2016-2-16 09:36:35 | 显示全部楼层
Every time a copy HEX file after entering DFU , DFU will restart .
Format the storage space , DFU no need to  formatting.
发表于 2016-3-31 17:51:12 | 显示全部楼层
[i = s] posts by jema in 2016-3-31 17:52 Edit
Hi.
I've DSO202 model with v1.28 firmware.
How can I update to v1.32 ? There are two files : DS202.A132.hex and DS202.B132.hex
I understood that:
- Enter DFU mode (4 sec power switch)
- Copy first file DS202.A132.hex from PC to DSO unit
- Reboot
- Enter DFU mode again (4 sec power switch)
- Copy second file DS202.B132.hex from PC to DSO
- Reboot again
Is it?
What means when you say "press the pause button"?:
DS202. A132. Hex - > APP1 (the default boot)
DS202. B132. Hex - > APP2 (press the pause button)
Thanks
发表于 2017-12-14 00:50:14 | 显示全部楼层
Hello !
I have problem upgrading my DS202 V3-42DV1.32 APP1 hardware V2.22 to to vV1.37 version.
After copying DS202.A137.hex to DFU, I get DS202.A137~error.
Can U help ?
Many thanks from Europe
发表于 2017-12-14 09:28:57 | 显示全部楼层
GATSBY 发表于 2017-12-14 00:50
Hello !
Aft ...
What's your PC system? If it's winXP, try switching to Windows 7.
To make sure that your firmware is downloaded from the website, you can try the firmware's name with a length of less than 8, eg: DS202. Hex.
There is no problem to upgrade normally, I hope I can help you.
回复 1 0
发表于 2017-12-14 17:55:17 | 显示全部楼层
Hello and many thanks for your prompt answer.
My system is Version Linux Mint 18 Sarah 64-bit, Noyau Linux 4.4.0-101-generic x86_64, desktop MATE 1.14.
I've downladed the firmware from http://www.minidso.com/forum.php ... 2Bfirmware%2Bupdate
Does not work changing the name in DS202.hex ; i get DS202~ERR
I did succed to upgrade to the actual version when i received my DS202 two years ago but as i am 65 years old and i don't remember how i did it ....
Do i have to ger rid of the Sytem Volum Information folder before ?
Thanks again for your help.
发表于 2017-12-15 09:19:24 | 显示全部楼层
My system is Version Linux Mint 18 Sarah 64-bit, Noyau ...
There are many versions of Linux, and there may be a small number of versions that do not support DFU mode, but win7,win10, and MAC are all supported.If you can, upgrade the firmware on the above system.
发表于 2017-12-16 19:36:03 | 显示全部楼层
Hello !
I already upgrade my DS202 to 1.32. So my version of Linux does not seems to be the problem.
II will try to find a windows computer and let you know.
Many thanks anyway for your help.
发表于 2017-12-18 17:12:35 | 显示全部楼层
sagittarius Posted 2017-12-14 09:28
To make sure that your firmware  ...
Hello !
It works with window 7. It's a Linux Mint comptability problem.
Thanks for your help.
GMT+8, 2026-11-11 14:36 , Processed in 0.151111 second(s), 19 queries .
