楼主: beo
[Troubleshooting] MDP-P906 turns on and instantly off when powered via USB-C PD
 楼主| 发表于 2024-8-19 21:10:24 | 显示全部楼层
I tested the MDP-P906 on a "Anker Prime Charger (250W, 6 Ports, GaNPrime)" and the MDP-P906 it doesn't even turn on - no matter which port or mode I use.
The TS80P (PD, 11 V) and the MPD-L1060 works fine though (and all of my other devices)
https://www.anker.com/eu-en/products/a2345-anker-prime-charger-250w-6-ports-ganprime?ref=naviMenu&variant=44458529652926
发表于 2024-8-20 09:21:05 | 显示全部楼层
We are trying to improve the PD compatibility of P906 through software, please be patient.
 楼主| 发表于 2024-8-20 13:57:18 | 显示全部楼层
Thanks a lot!
回复 0 1
发表于 2024-8-31 00:14:07 来自手机 | 显示全部楼层
beo 发表于 2024-8-20 13:57
Thanks a lot!
Could it be that it's not supported when PPS, programmable power supply, is supported.  I have a 3 port gan 66w oreimaccharger that turns off also and it supports PPS.
What i find is that if i only use one of the usbc ports then the p906 turns on, but if i have two p906 commented to the two usbc ports at the same time then the p906 turns off exactly like shown in the video.  Also if i connect the mdp-l1060 and a mdp-p906 both to the usbc ports then the p906 turns off after it boots up, so it's since this is I'm using both usbc ports that are PPS ports regardless if no devices are powered on; the second connected device doesn't need to be powered on, but only connected to the second USBC port.
Now, i can get it to stay on with multiple devices, p906, etc, connected to the same 66w charger if i hold the on button, p906, through the full boot cycle,
So why will the p906 stay powered on if i hold the power button for about 5 seconds, but if i hold the power button for only 2 seconds then it turns off after booting, but only if multiple devices are connected to the dual usbc PD ports.
https://www.sortabase.com/GANchargers/post/clblj1fp12245301mu58w5kbrt
发表于 2024-8-31 00:30:11 来自手机 | 显示全部楼层
So why will the p906 stay powered on if i hold the power button for about 5 seconds, but if i hold the power button for only 2 seconds then it turns off after booting, but only if multiple devices are connected to the dual usbc PD ports.  This is when I'm using 2 miniware e-marker 240w cords.
Also, if I'm using the 1 usbc port for a p906 with usb3.0 cords then it powers on and if i use 2 usbc ports with usb 3.0 cords then both p906 devices will power on. The first time they powered on, both turned off after 8-10 seconds, but i turned them both back on and they stayed powered on. I didn't hold the power button for more than 2 seconds, so it seems that if i just instantly reboot the devices then they stay powered on.
It seems like this may be related to PPS support and possibly PD e-markers as well.
发表于 2024-9-2 08:56:40 | 显示全部楼层
Botech 发表于 2024-8-31 00:30
Could it be that it's not supported when PPS, programmable power supply, is supported.  I have a 3 ...
We will test this issue and continue to improve the compatibility of P906 through software upgrades.
回复 1 0
发表于 2024-9-10 23:17:12 来自手机 | 显示全部楼层
minidso 发表于 2024-9-2 08:56
We will test this issue and continue to improve the compatibility of P906 through software upgrade ...
The MHP50 works with the same 140w charger with no issues.
发表于 2024-9-19 09:08:14 | 显示全部楼层
It helped for me to downgrade to v1.32 firmware, so now it works with my Lenovo 65W PD adapter.
发表于 2025-1-10 04:16:25 来自手机 | 显示全部楼层
Hello! I have similar problem. Just purchased Ugreen Nexode 200W power bank (https://eu.ugreen.com/collections/power-bank/products/ugreen-nexode-power-bank-200w-25000mah) and it acts the same way as described in this thread. I updated my firmware of P906 but acts the same way. Any solution for this problem because this power bank was purchased only for one reason - to power my power supply 🫢
发表于 2025-1-10 09:22:09 | 显示全部楼层
Toomas 发表于 2025-1-10 04:16
Hello! I have similar problem. Just purchased Ugreen Nexode 200W power bank (https://eu.ugreen.com/c ...
I don't have the model of mobile power you mentioned, so I can't test it.
But if this mobile power supports the standard PD protocol (not the protocol modified by the manufacturer) and supplies power to the P906 through the C2C power cable, then it is possible.
回复 1 0
GMT+8, 2026-11-6 01:00 , Processed in 0.157916 second(s), 21 queries .
