楼主: atuleu
Allow for lower temp settings with MHP50
发表于 2024-10-5 21:05:20 | 显示全部楼层
Hello, any updates on the next release, please? Thank you!
发表于 2024-10-8 09:10:17 | 显示全部楼层
MHP50 will have a major version update this month or next month, adding many features, including adjusting the temperature range for reflow soldering.
发表于 2024-12-5 06:30:43 | 显示全部楼层
I see that SV 2.00 has been posted.
Is that the version that fixes the issues listed?
What are the steps to perform the update?
Bruce
发表于 2024-12-5 09:29:07 | 显示全部楼层
- Modify reflow parameter range
- Add multi-language
- Add support for SA80/SA115/SA210/SA245 soldering station adapters
Firmware update method:
1. Press and hold the A button on the MHP50 console, connect the MHP50 to the computer with a USB Type-C data cable, enter DFU mode, the screen displays "DFU Mode V1.00", and a virtual disk "MHP50_DFU" will appear on the computer.
2. Copy the file "MHP50APPV200.hex" into the DFU disk, wait for the disk to restart and the "hex" file suffix to change to "rdy", then copy "MHP50UIV200.hex" into the DFU disk, wait again for the disk to restart and the "hex" file suffix to change to "rdy", disconnect the USB connection, and complete the firmware upgrade.
发表于 2024-12-11 10:07:50 | 显示全部楼层
Thank you for releasing v2.00.
I'm having trouble with the new reflow profile settings. The settings don't seem to work. For example, regardless of what WeldTemp is set to, the maximum temperature during reflow reaches 230 C. RiseTime and KeepTime also don't seem to be respected.
Does anybody else see this issue?
GMT+8, 2026-11-6 00:59 , Processed in 0.146102 second(s), 19 queries .
