楼主: minidso
Material Download For MHP50 Mini Hot Plate Preheater
发表于 2024-1-18 09:27:49 | 显示全部楼层 |阅读模式
2026.6.8:
MHP50 Mini Hot Plate Preheater APP V3.02: https://forum.minidso.com/forumdownload/MHP50APPV302.zip
- With Bluetooth enabled, it can connect to the MINIWARE mobile app
- Incorporate CP50 solder pot temperature curve and PID temperature control
MHP50 Mini Hot Plate Preheater Solder Pot Set User Manual V1.0 CN/EN/RU/DE: https://forum.minidso.com/forumdownload/CP50UserManualV1.0
2026.05.09:
MHP50 Mini Hot Plate Preheater User Manual V1.3 CN/EN/RU/DE: https://forum.minidso.com/forumdownload/MHP50UserManualV1.3.pdf
2025.1.9:
MHP50 Mini Hot Plate Preheater APP V2.01: https://forum.minidso.com/forumdownload/MHP50APPV201.zip
- Optimizing reflow temperature control
- Modify the minimum control temperature to 50 degrees Celsius
2024.12.02:
MHP50 Mini Hot Plate Preheater APP V2.0: https://forum.minidso.com/forumdownload/MHP50APPV2.0.zip
- Modify reflow parameter range
- Add multi-language
- Add support for SA80/SA115/SA210/SA245 soldering station adapters
MHP50 Mini Soldering Station Adapter User Manual V1.0: https://forum.minidso.com/forumdownload/MHP50 Mini Soldering Station Adapter User Manual V1.0.pdf
2024.05.24:
MHP50 Mini Hot Plate Preheater APP V1.01: https://forum.minidso.com/forumdownload/MHP50APPV101.zip
- Fix known BUG
- Modify the default value of DC power limit
- Added temperature calibration function
- Optimize screen display
2024.04.30:
MHP50 Mini Hot Plate Preheater User Manual V1.1 CN/EN/RU/DE: https://forum.minidso.com/forumdownload/MHP50UserManualV1.1.pdf
2024.01.18:
MHP50 Mini Hot Plate Preheater User Manual V1.0 CN/EN/RU: https://forum.minidso.com/forumdownload/MHP50UserManualV1.0.pdf
发表于 2025-4-13 23:24:35 | 显示全部楼层
hi when to expect a new fw update release?
 楼主| 发表于 2025-4-14 09:27:08 | 显示全部楼层
Thinking about what new features can be added.
发表于 2025-6-4 18:39:23 | 显示全部楼层
Please, please unlock the minimum temperature to 30 degrees
A lot of people ware aiting for that
发表于 2025-6-4 22:19:39 | 显示全部楼层
Thanks 30 degree really needed
 楼主| 发表于 2025-6-5 09:29:17 | 显示全部楼层
What can do under 30 degree?
发表于 2025-6-9 19:21:36 | 显示全部楼层
to program a "cool down"
发表于 2026-1-27 20:01:32 | 显示全部楼层
Hi, any news about the new fw?
 楼主| 发表于 2026-1-28 09:05:09 | 显示全部楼层
A version that supports control via a mobile app will be released soon, please wait.
发表于 2026-2-19 00:42:40 | 显示全部楼层
such a good news
GMT+8, 2026-10-18 15:10 , Processed in 0.175108 second(s), 21 queries .
