楼主: minidso
Material Download For DT71 Mini Digital Tweezers
发表于 2021-1-6 10:53:37 | 显示全部楼层
malorkus 发表于 2021-1-5 06:56
Just got my DT71 with 1.05 firmware. I downloaded 1.08 from the top of this page and put DT71APP108. ...
Please use another computer and try again.
销售店铺  ccdso.taobao.com
(Miniware代理商)
发表于 2021-1-6 14:14:03 | 显示全部楼层
Maybe the firmware was not updated successfully. After downloading the firmware file, unzip it to the computer hard disk. Don't open the compressed file and copy it.
If you can, please take a video. Share the link here.
(Miniware代理商)
发表于 2021-1-7 05:41:04 | 显示全部楼层
I tried on two different computers - both Macs - and I get same result each time. Updaing the firmware on my ES121 works just fine.
I don't have a video, but there's nothing to show.
I unzipped the file to extract DT71APP108.hex and then copied DT71APP108.hex to the FT71 using the terminal. (If I use drag-drop, the file becomes DT71AP~1.ERR so I use the terminal, which seems to work.)
Then, the drive is unmounted and remounts seconds later. The file becomes DT71AP~1.RDY. Then I unplug and plug it back in.
When connected to USB, display reads DFU:V3.52 5.246V
When connected to test arms, display reads DT71 V1.05
I also tried using a Raspberry Pi to copy the file, but the flash drive doesn't seem to be mountable on rpi/linux.
 楼主| 发表于 2021-1-8 09:50:32 | 显示全部楼层
malorkus 发表于 2021-1-7 05:41
I tried on two different computers - both Macs - and I get same result each time. Updaing the firmwa ...
Can you try windows? Win7 and win10.
发表于 2021-1-26 18:34:21 | 显示全部楼层
Need to rename the file "DT71APP108.hex" => "DT71.hex"
发表于 2023-5-12 16:07:37 | 显示全部楼层
Hello, I'm trying to figure how out how to set the default measurement mode.
I need to set it to measure voltage by default.
Can anyone help?
Thank you,
 楼主| 发表于 2023-5-15 09:10:19 | 显示全部楼层
DT71 can't set the default measurement mode to voltage when it starts up
GMT+8, 2026-11-6 01:00 , Processed in 0.171050 second(s), 19 queries .
