楼主: minidso
[Firmware update] Material Download for MDP Digital Power Supply
 楼主| 发表于 2024-7-22 08:59:48 | 显示全部楼层
pierce 发表于 2024-7-19 12:29
Can you post the MDP-L1060 APP V1.02 ?
I bought an MDP-L1060 a few months ago, and it came with FW  ...
Will post the V1.02 soon, Please wait.
发表于 2024-7-25 07:25:11 | 显示全部楼层
OK, thanks!
发表于 2025-7-7 23:15:38 | 显示全部楼层
Hello, I have a question for some reason i can't download this version of firmware:
MDP-P906 APP V2.02 :  https://forum.minidso.com/forumdownload/MDP-P906_V2.02.zip
The link says:
Not Found
The requested URL /forumdownload/MDP-P906_V2.02.zip was not found on this server.
 楼主| 发表于 2025-7-8 09:00:45 | 显示全部楼层
MDP-P906 APP V2. ...
We are fix it , please wait.
发表于 2026-9-10 20:34:48 | 显示全部楼层
Currently, the MDP-P906 voltage converter has the latest firmware version 3.01, and the MDP-M01 display module has the latest firmware version 2.03.001.
Today, I encountered an annoying issue with the voltage converter, which could even be considered a malfunction or a software glitch. It manifests itself as follows: if I adjust the output voltage in tens of volts, then when the voltage drops from 30 to 29 volts, the converter simply shuts down. This happens very frequently, requiring me to restart the voltage converter over and over again. I've made a video demonstrating the problem ( https://www.youtube.com/watch?v=Z_IIk3GwrrI ).
I also noticed that the voltage converter shuts off when the output terminals are activated and the voltage drops from 30 to 29 volts.
In both cases, the voltage converter was powered via the USB-C port using the Power Delivery protocol.
Please tell me what this is related to, and how can I solve this problem?
发表于 2026-9-10 21:42:01 | 显示全部楼层
Hello! if I adjust the output voltage in tens of volts, then when the voltage drops from 30 to 29 volts, the converter simply shuts down. https://www.youtube.com/watch?v=Z_IIk3GwrrI
 楼主| 发表于 2026-9-11 10:22:05 | 显示全部楼层
demalit 发表于 2026-9-10 20:34
Currently, the MDP-P906 voltage converter has the latest firmware version 3.01, and the MDP-M01 disp ...
I actually tested it and it won't have the same problem.
Can you try testing with other power sources? Also, do not connect M01, only use P906, and see if the same phenomenon occurs.
发表于 2026-9-11 22:47:55 | 显示全部楼层
Can you try testing with other power sour ...
Thanks for the reply! This issue only occurs when adjusting the voltage using the MDP-M01 module. If I adjust the voltage on the MDP-P906 power module itself, there are no shutdowns.
GMT+8, 2026-11-5 19:51 , Processed in 0.147021 second(s), 18 queries .
