楼主: nikwest
TS80 does not heat up - Low Vot error
发表于 2018-12-5 17:40:23 | 显示全部楼层
marshaul 发表于 2018-12-5 00:19
I have the same issue when using my Nekteck 10050 mAh power bank (model 10050QC3).
My TS80 works fi ...
Please try the 1.07 version APP
http://minidso.com/forum.php?mod=viewthread&tid=3208
发表于 2018-12-6 04:33:03 | 显示全部楼层
minidso Posted 2018-12-5 17:40
Thank you for a new firmware version. Sadly, it doesn't seem to fix the problem for Omars powerbank, even the workaround doesn't work anymore.
Do you publish the source code as for 1.06? I could take a look, perhaps I'm able to help...
发表于 2018-12-6 04:48:50 | 显示全部楼层
I am sorry to report that 1.07 still does not work with the Nekteck power bank, and the workaround does not work either.
发表于 2018-12-6 10:07:15 | 显示全部楼层
App 1.07 , fix some bug of the "low vot"
You can download the source code of 1.06 here:
发表于 2018-12-7 05:59:30 | 显示全部楼层
Let me know if there's any information I can provide to assist in resolving this issue.
I'll take a look myself if I can find time to learn QC3 negotiation.
发表于 2018-12-7 11:51:52 | 显示全部楼层
I'll take a ...
I email you
 楼主| 发表于 2018-12-13 03:37:43 | 显示全部楼层
Steini Posted 2018-12-3 05:50
@nikwest: I made good progress in analyzing the code and quickcharge negotiation. Please confirm tha ...
I can confirm that this workaround is working with the 1.06 version and Omars power bank. Thank you very much for your help.
 楼主| 发表于 2018-12-13 05:41:24 | 显示全部楼层
I upgraded to version 1.07 and it still does not work with the Omars power bank. Also the work around does not work anymore.
发表于 2018-12-13 05:57:23 | 显示全部楼层
nikwest Posted 2018-12-13 05:41
I upgraded to version 1.07 and it still does not work with the Omars power bank. Also the work aroun ...
Sadly, MiniDSO didn't yet published the source code of their firmware version 1.07, so I could only do a fix based on 1.06 if this would help.
发表于 2018-12-13 09:42:26 | 显示全部楼层
Steini 发表于 2018-12-13 05:57
Sadly, MiniDSO didn't yet published the source code of their firmware version 1.07, so I could onl ...
Preparing to open 1.07 source code, please wait
GMT+8, 2026-11-6 01:00 , Processed in 0.160957 second(s), 21 queries .
