楼主: minidso
[第三方资源] 【参赛作品】Alternative dso firmware 作者:gabonator1【贡献奖】
发表于 2013-4-27 16:49:21 | 显示全部楼层
这个版本只占一个app,我装在app1,app 2,3,4不受影响
发表于 2013-9-1 23:12:43 | 显示全部楼层
HELP! I download APP_G251.rar, unzipped it , and copied it to folder DFU V3_12_C (which was empty when I started and is empty again after restarting) and now I have only a grey screen.  I started with splash screen: "Hardware Ver V2.72  SN #7D19A881  DS203 min DS203 SYS Ver 1.60  DS203 Mini DSO APP (Plus A1) Ver 1.10 Reload parameter form disk"  What do I do now??  I am a newbie!
 楼主| 发表于 2013-9-2 10:10:38 | 显示全部楼层
回 jrb651 的帖子
jrb651:HELP! I download APP_G251.rar, unzipped it , and copied it to folder DFU V3_12_C (which was empty when I started and is empty again after restarting) and now I have only a grey screen.??I started with splash screen: "Hardware Ver V2.72?&nb ..?(2013-09-01 23:12)?
APP_G251 is unofficial version app. Developers by pmos69 in seeedstudio's forum.
you need used in conjunction with SYS 1.50 1.6 from Marco Sinatti. you can down it in :http://seeedstudio.com/forum/vie ... 193e3ad302f13b96597
发表于 2013-9-2 21:20:57 | 显示全部楼层
回 minidso 的帖子
minidso:APP_G251 is unofficial version app. Developers by pmos69 in seeedstudio's forum.
you need used in conjunction with SYS 1.50 1.6 from Marco Sinatti. you can down it in :http://seeedstudio.com/forum/vie ... e39bc7b5e1347193e3a ..?(2013-09-02 10:10)?
Thank you, but before I do more damage, how do I restore (find)  the original firmware?  I need to go out into the field and collect some data and then have someone else look at it and I was having trouble figuring out how to save/reload data.  The APP_G251 looked like a better way to do what I need.  Will it work with my hardware v2.72 if I install SYS 1.50?  Does upgrade V3.12C work the same as V3.10D?  The folder is empty when I view it on my PC.  Is that normal?
 楼主| 发表于 2013-9-3 10:36:45 | 显示全部楼层
you can download original firmware in http://www.minidso.com/bbs/read.php?tid=67 , the latest version is PA1_V110 and SYS_B160. the app_g251 have a different operating. it can run on hardware 2.72 and sysb160. If you can't run it ,you can try to use sys 1.5.
DFU 3.12C is the latest version. some change with 3.10D. every time you start dfu mode, it's empty,then you can copy *.hex to upgrade program.
发表于 2017-2-20 15:33:58 来自手机 | 显示全部楼层
Seeedstudio 和 minidso 到底是什么关系?还有E-design
 楼主| 发表于 2017-2-20 16:09:05 | 显示全部楼层
只要是e-design所设计的产品,产品上都会标明design by e-design字样。
发表于 2017-4-21 06:08:47 | 显示全部楼层
[i = s] posts by Micha in 2017-4-21 06:10 Edit
Hi!
I have a license error for my ds203.
my S/N 9417D17E
     H/v 2.60
Help me please !!!!
发表于 2017-4-21 06:12:46 | 显示全部楼层
[i = s] posts by Micha in 2017-4-21 06:15 Edit
This happened after the firmware
 楼主| 发表于 2017-4-21 09:40:22 | 显示全部楼层
Hi!
Try 8862F629 or 7DC8F4C0
GMT+8, 2026-11-24 05:29 , Processed in 0.170258 second(s), 19 queries .
