楼主: sam
A licence code please!
发表于 2016-12-15 03:46:44 | 显示全部楼层
Hi guys,
could you help me with license number for my DS203 v2.72
Serial is: 7A14C06A
Thank you very much for your help!
发表于 2016-12-15 09:33:35 | 显示全部楼层
sermartynov 发表于 2016-12-15 03:46
Hi guys,
Try F321706B
回复 1 0
发表于 2016-12-15 14:47:12 | 显示全部楼层
minidso 发表于 2016-12-15 09:33
Serial is: 7A14C06A  Try F321706B
does not work says " Licence input error"
发表于 2016-12-16 09:35:46 | 显示全部楼层
Or , DD4EDBEB
发表于 2016-12-24 00:36:21 | 显示全部楼层
Thank you it worked
发表于 2017-1-5 07:49:42 | 显示全部楼层
could you help me with license number for my DS203 v2.72,
DFU3.14
Serial is: D306C49E
发表于 2017-1-5 09:42:25 | 显示全部楼层
Try: 73F902EA
Can you tell me what the reason for you need the serial number?
发表于 2017-1-11 06:23:15 | 显示全部楼层
minidso Posted 2017-1-5 09:42
Try: 73F902EA
73F902EA - doesn't work, says "Licence input error", could you please consider my DFU version is 3.14?
The reason my asking the license is electrostatic discharge with my finger, that damaged the scope. I didn't expect it first broke the hardware, and trying to reinstall firmware until make it the "full brick"...
So, finally, I uploaded FW via UART, found out that on-board "step down converter U15 QX3406AL" is broken, replace it with NCP1529ASNT1G. Heh, it works perfect now!!! Just needs correct licence code.
PS: FUI, NCP1529ASNT1G has static protection, perhaps it's better to use.
发表于 2017-1-11 09:19:33 | 显示全部楼层
240974a 发表于 2017-1-11 06:23
73F902EA - doesn't work, says "Licence input error", could you please consider my DFU vers ...
Try : A0B4775F
发表于 2017-1-11 09:31:39 | 显示全部楼层
Perfect, works!
GMT+8, 2026-10-20 23:48 , Processed in 0.140108 second(s), 19 queries .
